AutoCAD Forum
Only snapping when I change to my last sheet
2 REPLIES 2
drawingsCHR7R
303 Views, 2 Replies
Hi all,
I am currently experiencing a weird problem that I don't know how to fix:
So I currently have 4 sheets that i use, on the first 3 sheets when i use the move command the movement is smooth and easy to use, when I go to my last sheet and try to use the move command it is as if it is snapping to some sort of grid, thus I cannot get precise or small movements. This is very frustrating and I feel as though i am missing something. How do I fix this?
All help would really be appreciated. Thanks
2 REPLIES 2
imadHabash
in reply to: drawingsCHR7R
if you press  F9  , any changes ?
Imad Habash
drawingsCHR7R
in reply to: imadHabash
Worked perfectly, thanks a lot!
Forma Design Contest
AutoCAD Beta
