OLE xlsm file location
kameron.jones
Message 1 of 8
kameron.jones
I posted a very similar question earlier, and thought I would ask a different way:
Is there a source location that an embedded file (in my case, .xlsm) opens from outside of AutoCAD. IE when I say "OLEOPEN" and my excel file opens, the title says "worksheet in Drawing1.xlsm"
Does anyone know where this .xlsm is temporarily stored so I can try to add it to a trusted location, so the macros work?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
If it's really embedded, then the content is only saved inside the dwg-file itself.
The advantage of embedded is that you can send the dwg-file to someone else and he can open the OLE-object content (if the software for that exists on this workstation) ... without the need to transfer any other files.
BTW: Be careful ... as XLSM can include macros you might transfer virus content too! Also antivirus software might show warnings for such files.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
kameron.jones
Thanks, so then I suppose, is there a way to make that file trusted?
Message 4 of 8
Alfred.NESWADBA
Use XLSX instead of XLSM, AutoCAD itself does not make anything trusted or not ... the workstation that should open the file may have issues with that.
- alfred -
Alfred NESWADBA
Message 5 of 8
Ed__Jobe
It depends on whether the xls was embedded or linked. If linked, use the OLELINKS command. If embedded, you can export the OLE to a file by selecting the OLE>right click>OLE>Convert.
However, don't expect the OLE to run excel macros. Your best option is to link the file using datalink manager, placing a linked table and then running the macros in the xlsm and then updating the table in AutoCAD.
Ed
How to post your code.
Message 6 of 8
kameron.jones
it is at large our company policy and the new microsoft updates that forced macros to be disabled. i am trying to figure out how to "trust" this document rather than recreate the OLE
Thanks for your input, I am thinking it will have to be a new "simple" OLE
Message 7 of 8
Ed__Jobe
Just save the xlsm as an xslx and it will remove the code for you. Also, better than an OLE, use a datalink to the xslx or xlsm and create an AutoCAD table based on the datalink.
Ed
Message 8 of 8
kameron.jones
The issue is that the code is a key part of our OLE.... to "just " remove it means we first have to recreate the OLE to produce what we need for our outcome. Also, a linked OLE will not work as this would affect multiple files at once, each of which need to be separate.
