OLE object doesn't show up
paohui1999
paohui1999
Hi~experts I am unable to see the picture I tried to insert via OLE into AutoCAD,I can only see the frame outside like the picture i attached in here.
Hope for an early response.
imadHabash
I suggest to try :
  • Type Ucs command then select World option .
  • Type Plan command then twice enter.
any changes ?
Imad Habash
Valentin_CAD
@paohui1999 ,
Check your TRANSPARENCYDISPLAY is set to "1" (on).
Otherwise check this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
Greetings @paohui1999
You may be having that issue because of these UCS rotations
Was your PLAN command set to CURRENT UCS before you attached the OLE? Might be worth testing that, remove the OLE, make the changes, reattach.
paohui1999
Thank you so much, it works now.
ingenieria16MRJF
Community Visitor
Community Visitor
It worked for me, thank you @imadHabash
vandenoosterkamp
seems a bug to me... it only shows the image in the EXACT same view or ucs in which it was initially pasted. Now comes to funny part...
- draw a line, creat a ucs that has origin and direction from that line. Plan
- save that view, make sure to save the ucs with the view, that's an option
- past something
- restore wcs, plan
- now make that ucs again, using the line you used earlier
- plan
------------------> empty frame
now restore the saved view -----> OLE shows
few days ago I heard a great joke: report it and autodesk will look at it
