Message 1 of 10
I have a rectangle model that reduces its thickness by half at the middle of the length and then increases to normal size again. the dimensions are as follows
0.4 x 0.4 x 10 mm starting at z=0 (large rectangle)
0.2 x 0.2 x 10 mm (small rectangle) (small rectangle is not at the z=0 but is at the middle of the large rectangle, it is placed at z= 0.1-0.3 mm)
Basically, the total length is 50 mm as;
10 mm large rectangle + 10 mm transition zone + 10 mm small rectangle + 10 mm transition zone + 10 mm large rectangle.
I could not model this as a 3D object and have no idea how to do it. Any ideas?
