Narrowing object
Narrowing object
i.erbay1
Message 1 of 10
Narrowing object
i.erbay1
I have a rectangle model that reduces its thickness by half at the middle of the length and then increases to normal size again. the dimensions are as follows
0.4 x 0.4 x 10 mm starting at z=0 (large rectangle)
0.2 x 0.2 x 10 mm (small rectangle) (small rectangle is not at the z=0 but is at the middle of the large rectangle, it is placed at z= 0.1-0.3 mm)
Basically, the total length is 50 mm as;
10 mm large rectangle + 10 mm transition zone + 10 mm small rectangle + 10 mm transition zone + 10 mm large rectangle.
I could not model this as a 3D object and have no idea how to do it. Any ideas?
Replies (9)
Message 2 of 10
Patchy
Like this?
This is only 1/2 to fit the screen.
All Squares not Rectangles?
Message 3 of 10
i.erbay1
Yes! I need this as .stl though, whenever I try to have it as a solid object, I receive errors and cannot merge the lines.
Message 4 of 10
Patchy
Try this and STLOUT
Message 5 of 10
WeTanks
Please refer to the attached documnet.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 6 of 10
i.erbay1
Thank you,
I was able to export it as stl but it seems there is an issue with the sizing after exporting or is it just me.
Message 7 of 10
i.erbay1
Thanks, I could not open the file as I dont have objectarx and using autodesk autocad and had a licence issue with your file. Any chance you could upload the .stl?
Message 8 of 10
Patchy
Try this stl
Let me know if it works.
Message 9 of 10
WeTanks
We.Tanks
図面一括印刷
Message 10 of 10
i.erbay1
thank you both, it worked
