OLE linked MS Word document does not update
DubbleBee
DubbleBee
I started a new sheet where I took an MS Word document that has 17 pages and copied and pasted special with the linked box checked each page into the AutoCAD drawing. The sheet looks and prints great but the problem I have is that when I use OLE update, the pages do not update. When I click on Open Source, I get the message "Failed to Launch server application". Did I do something wrong? Does this method of linking a multi-page MS Word document work? Does each linked page need to be associated with a single page document instead of a multiple page document. Any help would be appreciated.
vinodkl
Have you checked this : click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Ed__Jobe
Was the Word file moved or renamed?
Ed
How to post your code.
DubbleBee
My drawing is a new page and the linked document in new and has not been renamed or moved. It is however located across our network on another drive if that matters.
pendean
Community Legend
Community Legend
Did you recently change AUtoCAD or MSWord versions by chance? Your error message is a system level alert.
Or purchase this if you need this ability all the time in many files on many projects http://dotsoft.com/word2cad.htm
DubbleBee
Dean,
We didn't go through any changes or upgrades in our AutoCAD or MS software. The documents haven't been renamed or moved. I tried the suggestion of converting the Word document to PDF and back to Word which didn't work for me. I literally created the CAD drawing with the OLE links a few days ago and experimented with making changes to the Word document later the same day to make sure the links were going the update properly. That's when I discovered that the OLE update function wasn't working. It looks like the word2cad plug-in may be my only option. Thanks.
