hi @morganrj,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If you select one of the pieces of text and look at its properties, check to see which Text Style it has. Then open the Text Style manager (ST) and selct the same style on the left hand side. Once it is selected, look at the Font Name. If it has a little warning icon by the name then the font is either missing or damaged and an alternate font is being used instead. Is this what you see in your drawing?
John Vellek
