Offsetting a shape that has a round corner made with Fillet command
Message 1 of 8
There is an image that I have attached to this post, in that image the left middle shape is made by several lines and arcs which are then joined together by 'join' command.
The upper left corner of the middle shape which is 90 degree arc is made by 2 intersecting lines and then the 'Fillet' command gives it the round 90 degree shape
The outer and inner shapes in the left side is made by using 'Offset' command on the middle shape but there is a difference in outer shape and inner shape rather than the size.
The 'Offset' command has treated the middle shape in a way that the upper left corner is sharp has no round shape but when it comes to the inner shape, the 'Offset' command treats the corner as a round shape
On the left side I tried to do the same thing but this time I used 'Polyline' command instead of drawing lines and curves and joining them by 'Join' and this issue didn't happen
Why does this happen with 'Fillet' command and also different reaction to inner and outer offsets ?
Replies (7)
Message 2 of 8
GustavoUbriaco
Hi!
In your example both figures are different, try to make them equal and you'll have the same results
the arc dissapears because is too short in the offset result when the arc moves to left side they dicrease, to righ side they grow.
Gustavo Ubriaco Contreras
Message 3 of 8
First even if what you are saying is true, the outer offset and inner offset are still different from each other !
And why shouldn't offset treat my left side shape differently from the right side shape based on the size ?
Message 4 of 8
S.Faris
The reason why you are loosing your arcs while offsetting it inwards is because your Arc radius is less than your Offset value. For example you cannot offset a 200mm radius arc towards its center with a value equal or more than 200mm.
In simple words, An arc cannot have a negative radius value.
SALMANUL FARIS
Message 5 of 8
Actually the arcs are getting offset inwards properly despite the reason you mentioned !
I'm having problem offsetting objects outwards as it's shown in the attached image
Message 6 of 8
S.Faris
Eventhough you are offsetting outward. It is towards the center of the arc right? That's the error
SALMANUL FARIS
Message 7 of 8
So you mean when the shape get offset outwards, the radius of the circle in the corner also increases, and if the sides of the corner get smaller than the circle radius then that quadrant of the circle can't fit in the corner and as the result AutoCAD makes that corner sharp. Did I get you right?
Message 8 of 8
S.Faris
Exactly. Since a negative value Arc is impossible. Autocad 0 Degree fillets the corner where you previously had the arc.
SALMANUL FARIS
