- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
There is an image that I have attached to this post, in that image the left middle shape is made by several lines and arcs which are then joined together by 'join' command.
The upper left corner of the middle shape which is 90 degree arc is made by 2 intersecting lines and then the 'Fillet' command gives it the round 90 degree shape
The outer and inner shapes in the left side is made by using 'Offset' command on the middle shape but there is a difference in outer shape and inner shape rather than the size.
The 'Offset' command has treated the middle shape in a way that the upper left corner is sharp has no round shape but when it comes to the inner shape, the 'Offset' command treats the corner as a round shape
On the left side I tried to do the same thing but this time I used 'Polyline' command instead of drawing lines and curves and joining them by 'Join' and this issue didn't happen
Why does this happen with 'Fillet' command and also different reaction to inner and outer offsets ?
