3rd party block inserted into Model but doesn't show in Layout. I have read suggestions in other postings but nothing seems to work. I tried exploding the block and rewriting it, making ANNOALLVISIBLE. Nothing seems to work. Please help. I have attached dwg file. Problem is with Wolf 30 inch induction cooktop in Construction Layout
Solved by pendean. Go to Solution.
Any reason you opted not to EXPLODE and continue to EXPLODE that block off to one side to find the answer?
I did: all of that block's content is color RGB 255,255,255, aka "invisible". You probably wanted color 7 or better yet, BYBLOCK or BYLAYER. Note, it also has many layers of nested blocks and more blocks, and eve more blocks, all with that same setting.
HTH
@brenda2YUUT - It appears just fine on my side. But as @pendean noted, it's because of the object colours assigned to the block. 🙂
