objects exist but not visible in the model space
sampath.jeedigam
sampath.jeedigam
Hello Team AutoCAD,
I have a dxf file which I am opening in the AutoCAD 2021. It has some invisible objects which I would like them to appear on the model space, but not sure how to do it. I can't select individual objects, too. I am completely blocked here and there's no way to proceed with my later stages. I have deleted the visible objects and saved only invisible objects in a new dxf file. I have tried unhide/unisolate, REGEN, AUDIT but no use. There are no hidden layers and no proxies. I can only see the selection of the objects when I do a CTRL+A or quickSelect all the objects as shown below:
You can also see the invisible objects getting selected in the original file as shown below:
Because of size restriction, I have uploaded the invisible graphics file here (safe to download): Link to Invisible Objects.
Are these graphics valid? If yes, Is there any setting that determines the display of these objects? Am I missing anything? Please show me a way to display these graphics in the model space. Waiting for your reply.
Regards, Az.
Patchy
These are your invisible objects.
sampath.jeedigam
Hey thanks a lot. Can you please tell me how did you do that? Were the graphics readily visible when you opened the file in model space? If not, what should I do to make these graphics visible? I am using both AutoCAD 2021 and 2024 and was unable to see these graphics by trying things which I have mentioned earlier. If the graphics were readily visible, which AutoCAD version are you using?
It would be useful if you can tell me the process involved as I have to tell the same process to one of our clients. For now, I can make use of your image to confirm that there are few graphics. I appreciate your time, thanks & cheers!
Patchy
sampath.jeedigam
thank you, it worked!
