Objects exist on drawing but are invisible
Message 1 of 8
Hi
I have received a drawing from a client that uses our software that has somehow made the elements on a layer invisible despite the layer being unfrozen, etc. I have confirmed that the elements still exist on the floorplan by using the QSELECT command after Block Reference and then the "FPMerchandising" layer - there are around 260. Our software also recognises that the elements are present - we just cant see them.
I have attached drawing here to see what feedback i get, but i'm stumped. I have even tried selecting the End Isolation command, but no success.
Can you guys let me know what you think?
Replies (7)
Message 2 of 8
ActivistInvestor
Command: (setq ss (ssget "x" '((60 . 1))))
<Selection set: 294>
Command: (sslength ss)
756
Objects can be made invisible explicitly via code.
Your drawing contains 756 objects in model and/or paper space that are invisible. That doesn't include invisible objects nested in blocks (which aren't detected by the above code).
This will make all entities in model and paper space visible:
(defun C:MAKEVISIBLE ( / ss)
   (cond
      (  (not (setq ss (ssget "x" '((60 . 1)))))
         (princ "\nNo invisible objects found."))
      (t (setq i -1)
         (repeat (sslength ss)
            (entmod (subst '(60 . 0) '(60 . 1) (entget (ssname ss (setq i (1+ i))))))
         (princ (strcat "\n" (itoa (sslength ss)) " objects unhidden."))
   (princ)
Message 3 of 8
That worked!!!!
Thanks very much.
One thing i dont know though is how they did this so i can cater for it in the future? What command would get the drawing into this state?
Thanks again
Message 4 of 8
roland.r71
Isolate.
For Example: Right click any object, choose Isolate, then "Hide object".
-or- Click the [Isolate objects] button in lower-right corner.
The later is also the place to UNisolate objects.
When nothing is hidden, the button is all white (with a square, circle & triangle) & on mouse over it says: Isolate objects
Whenever an object is hidden, the button image changes (colors added), and on mouse over it says: Unisolate Objects. In that case, click it and choose: End object isolation, to unhide all objects.
Isolate = Hide all but selected.
Hide = Hide selected.
Message 5 of 8
Please explain how this was done?Or where to use this code rather?
Message 6 of 8
roland.r71
The DXF group code 60 stores whether an entity is visible or not. (60 . 1) = invisible (60 . 0) = visible.
His code selects all entities which are invisible (60 . 1)
and changes the entity data to become visible (60 . 0)
As to "where" to use the code ... open a drawing containing (posible) invisible objects, load the lisp file with the code & execute the function.
However, this function is completely obsolete, as it can be done by pressing 1 icon already present in ACAD, as i explained before (see post #4).
At the lower right corner there is an hide/isolate button that will do exactly that and more.
Message 7 of 8
scot-65
Perhaps look into disabling transparency?
Look at AutoCAD documentation for the variable
TRANSPARENCYDISPLAY.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 8
declan_g
@ActivistInvestor Thanks so much for this code, helped me out with a Cad file that had hidden objects even though the Isolate Object Icon bottom right was normal.BeforeBeforeAfterAfter
