Objects disappear when I use the move command
kevin_kroeger
kevin_kroeger
Just loaded AutoCAD 2024
When I select any object (block or text) and go to move it, it just disappears before I let go of button to place it.
rkmcswain
  • Make sure DRAGMODE is set to "Auto"
  • Check Hardware Acceleration, set it to the opposite of whatever it is now (enable it if off, disable it if on) and test.
paullimapa
pendean
Community Legend
Community Legend
Have you installed the2024.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
TheCADnoob
Have you tried running AUDIT on the file?
CADnoob
Kent1Cooper
Another possibility:  Do you have SNAP on at some very large value relative to the view area?
Kent Cooper, AIA
Valentin_CAD
@kevin_kroeger ,
Read these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
