> for example when i draw a line with 20 length units the line is so small"
The line is 20units long.
>and i should zoom in to see it clearly ..
If your previous view is far out, yes.
Do this
Type in ZOOM<enter>0,0<enter>100,50
and try it again, draw a line, 20units long
If you far away from a Skyscaper, it looks not so heigh, Go to the door and look to the top again..
or much more impressiv - go to the top one the edge and lok down.. High enough?
>also if i consider lengths in millimeters
Is this what you tried to show in your Video? Again: This dialog has nothing to do with real units of your lines in this file!
This setting is to say "Yes, I am working in Millimeters" and if you insert this File into another File via INSERT oder XREF command, AutoCAD can scale it the correct way for you (if in your target file, the units also set well).
>and i want to draw a 20 meters line ..when i insert 20,000 it draw a very long line
If you want to have a 20meter long line and you are drawing all in millimeters*, enter 20000 as line length,
if you want to have a 20meter long line and you are drawing all in meters*, enter 20 as line length.
...it is in your head only.
Set the "insertion units" in Units dialog well in all files, because it because the time will come when you want to insert one file into the other (as a block or as an xref)
and then AutoCAD can scale properly for you.
But while you're working in one file and not inserting other files, the setting is theoretically unimportant,
because it doesn't change anything for your input!
