Object Viewport Not Plotting
msanford.ail
msanford.ail
We have drawing that will print out the object viewport one 1 machine, but not on others with the latest patch/hotfix installed for AutoCAD 2017. any Ideas? I can upload the file if required.
Thanks in anticipation ๐Ÿ™‚
Replies (9)
Patchy
Upload, let's try it out
msanford.ail
Cad file uploaded as requested. The rectangular viewport plots fine, its the 2 circles that wont plot, either to our printer or to pdf.
Patchy
It's a glitch when making viewport from a polyline or a circle, if erase it will list as 2 objects.
Put viewport on its own layer and turn it off.
msanford.ail
Tried that, it didn't work. It must be a setting somewhere as it will print out on another machine that doesn't have the latest patch/hotfix installed
imadHabash
i plot it to pdf file and it's fine ( see attached pdf file)
Imad Habash
pendean
Community Legend
Community Legend
R2017.1.1update here and I'm not seeing any issues either
msanford.ail
And this is my frustration too. One of the machines in the office plots perfectly, 3 of the others don't.....
pendean
Community Legend
Community Legend
Then something is not identical between the one and the others in setup: weird indeed. It's not your file.
Did anyone ever solve this problem? I can only plot single sheets. Any time I create a sheet set or do a batch plot only the title block plots. None of the layers are turned off for printing. Also on the print preview they show up. Any suggestions or help?! I have the 2017 version. Also this is happening with multiple drawings. It didnโ€™t happen till someone sent me a 2019 DWG
