AutoCAD Forum
O menu superior não aparece
14 REPLIES 14
Message 1 of 15
620 Views, 14 Replies
Olá.
Uso o AutoCAD 2014, e hoje me deparei com o seguinte problema. O menu superior não aparece. Ele está lá, ao passar o mouse sobre ele, aparecem as shortcuts com as opções salvar, salvar como, etc. Porém, elas não aparecem.
Olá.
14 REPLIES 14
Message 2 of 15
imadHabash
imadHabash
try to restart your AutoCAD and - as a trial step- i suggest to change your color scheme to Dark from OPTIONS > Display.
Imad Habash
Imad Habash
Message 3 of 15
oswaldodcb
oswaldodcb
Hello @Anonymous,
Change workspace and return to the workspace where you are, this is to reload all the bars,
I hope it helps you
If my publication solved your concern Accept the SOLUTION
Oswaldo Caballero
Instructor ATC
Autodesk AutoCAD Certified User
Venezuela
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Hello @Anonymous,
I hope it helps you
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Message 4 of 15
in reply to: imadHabash
Hi, I've tried, but it does not work. The color scheme is already in the "dark".
Message 5 of 15
in reply to: oswaldodcb
Hy, I've tried. But in all workspaces, the menu doesn't appear yet. Thanks.
Message 6 of 15
oswaldodcb
oswaldodcb
Hi @Anonymous,
I suggest that you Reset Settings to Default your AutoCAD 2017 installation to see if that corrects the issue.
Attach a link that indicates how to apply the reset.
Https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
In this way you can repair any errors generated, I hope it is useful for you,
Best regards,
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Hi @Anonymous,
Best regards,
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Message 7 of 15
I'm using the 2014 version. I reset the settings, but nothing has change.
Message 8 of 15
oswaldodcb
oswaldodcb
I get it,
Type CUI and press Enter,
Verify that you have the Quick Access Toolbar as in the image and let me know,
regards
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
I get it,
regards
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Message 9 of 15
Message 10 of 15
user181
user181
What operating system are you using? Maybe it's not compatible with 2014. Have you tried changing your windows theme?
Message 11 of 15
in reply to: user181
I'm using Windows 10 Home Single Language. I already used this AutoCAD version in Windows 10 Pro, and it worked perfectly.
I've tried changing the Windows theme, but nothing changes.
Message 12 of 15
oswaldodcb
oswaldodcb
Try loading the .CUIX file with the MENU as in this video:
Https://www.youtube.com/watch?v=7VeL5gI8QKc
But try to follow the steps of this other video applied to Revit,
Https://www.youtube.com/watch?v=EqqFuFsszvY
Let me know if it works for you,
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Message 13 of 15
user181
user181
I think it has to do with windows 10. You can try the Aero Lite Theme but it takes a little work.
https://www.youtube.com/watch?v=dyDCa7202AA
Message 14 of 15
That worked, thank you. But only bellow the ribbon. When I choose to the "quick access toolbar" appear above the ribbon, it becomes invisible again01.PNG
Message 15 of 15
oswaldodcb
oswaldodcb
I understand, it can be problem of the graphical accelerator of your pc, or even problems of Windows 10 as comments @user181, however it is a temporary solution, I am glad that it works for you @Anonymous
Successful and always at your service!
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
Oswaldo Caballero
Instructor ATC
Venezuela
Oswaldo Caballero
LinkedIn
AutoCAD Inside the Factory
