Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
not able to copy paste
I just install 2018LT  and have ran into a problem with copy paste. The problem is here at the shop our plasma system uses autocad 2014 and can not be upgraded any more without buying a system. I drew a part in 2018 and tried to copy past from 2018 to 2014, when I selected paste in 2014 the part came in as a picture and not a part. How do I fix this?
TheCADnoob
I would chack to make sure the file versrions are the same/compatable.
I might also try COPYCLIP
CADnoob
chriscowgill7373
I had to use paste special as autocad entities.  This is always a problem when switching drawing formats.  I think the current drawing is in the current version all the time until you save it, then it saves as the old, but is still the current version. (makes sense in my head, hard to explain using words)
what about saving as a 2013 dxf, then opening it in 2014 and copy paste between drawings?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
sthompson1021
The short answer is that you can't copy paste between 2018 and 2014. It's 2 different dwg formats. One workaround would be to make a WBLOCK of the part and then save it. You would have to reopen it with 2018 and save as 2013 format to insert it into your 2014 dwg. Not a good option I know but short of staying with 2014, you are kind of limited.
sthompson1021
Nice answer, never thought of trying paste special.
Thank you for the answer, I kinda figured that's what it was going to be.
Scott Johnson
Drafting/Designer
Epcon Industrial Systems, LP -- EST 1977
Main 936-273-1774 Ext. 205
Fax 936-273-4600
[email protected]
www.epconlp.com
[EPCON Logo signature]
EST. 1977
Celebrating 40 years of Success
DISCLAIMER:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity named above. Be advised that any use, dissemination, storage, distribution, forwarding, or copying of this email is strictly prohibited and doing so may subject you to civil or criminal penalties. If you have received this transmission in error, notify the sender immediately and permanently delete the message from your system and destroy any hard copies you have printed. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of Epcon(r) Industrial Systems, LP. This transmission may also be legally privileged and constitutes an electronic communication within the protection of the Electronic Communications Privacy Act, 18U.S.C. 2510
