How do I make / create / export a .shp file?
I need some help for how to make / create / export a .shp file for use with linetypes.
I have found a lot of references online for how to use these files and what they are used for in linetypes, how to reference them, and how to compile the file. But I haven't yet found how do I actually make my own .shp file? I am using AutoCAD 2016 (2D).
Do I save or export as an .shp (haven't found that option), or is there a command I can type in the command line?
I am guessing this is so simple that there are very few posts about it. I just need help getting to the first step.
Thanks in advance!
DH
2016, linetypes, shape files, .shp, .shx, create, export, line types, line type, linetype, custom
TheCADnoob
Below is a screencast i created to create a shape and then a line type (starts around 2:10)
to create the Shape type MKSHAPE and follow prompts.
CADnoob
Thanks to TheCADnoob that was a really helpful screencast.
Now my next question is, if I want to view / edit / update an ".shx" file how would I do that?
I'd like to add a few shapes to the standard ltypeshp.shx file (in the "....\enu\Support" folder).  I can then distribute this file to others once it includes some additional shapes that are currently missing.
Thanks again,
DH
