None vertical and horizontal lines are light gray when PUBLISHING to pdf, but are black when PLOTTING single pages
WBROWNMG7FU
Message 1 of 9
WBROWNMG7FU
I regularly use PUBLISH to convert multiple pages to PDF. I am printing in Monochrome. When I use PUBLISH, every line that is not horizontal or vertical comes out light gray and hard to see, which is my issue. When I use PLOT, to plot a single page, all of the lines come out black and uniform, as expected. Obviously PUBLISH is the quickest way to plot multiple pages, so I would like to utilize it. I do not want to have to plot each page individually and then combine them into one package in Adobe, as it takes too much time.
The gray washed-out line issue only occurs when using PUBLISH. Anyone have a solution?
Thanks!
P.S. I tried uploading PDF examples, but was prompted that the file type (PDF) was invalid.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Sure they are PDFs? I seem to be able to add them here, no issues.
@WBROWNMG7FU wrote:
I regularly use PUBLISH to convert multiple pages to PDF. I am printing in Monochrome. When I use PUBLISH, every line that is not horizontal or vertical comes out light gray and hard to see, which is my issue. When I use PLOT, to plot a single page, all of the lines come out black and uniform, as expected....
I don't see screenshots of your PLOT and PUBLISH commands pop-up here "ready to do", can you do so now?
And a screenshot of your ABOUT command pop-up too please.
Your PDF Viewer is...?
And if you try a different PDF Viewer, does the problem go away?
Message 3 of 9
paullimapa
Are you using the same page setup to create the pdf when you use the Publish command?
Don't use <Default: None>
Create a page setup that uses monochrome.ctb and then use this page setup with Publish.
Or post a sample drawing so we can all take a look.
Paul Li
IT Specialist
@The Office
Message 4 of 9
WBROWNMG7FU
In regards to me not being able to upload "PDFs", the files type says "Adobe Acrobat Document"
Message 5 of 9
WBROWNMG7FU
Yes I use monochrome on each page. I do not used default none.
Message 6 of 9
WBROWNMG7FU
Actually, maybe I am using default none!
What I do is open a new drawing in a file that already has the page setup completed. But I just noticed that on the publish command that the page setup is default: none. I assumed that if each individual page was setup that the setting would follow over when using publish. How can I change the page setup in publish?
my only option is to "import".
Message 7 of 9
paullimapa
this means you don't have a page setup created in the drawing and I see in your page setup screen shot window that it is set to <None>. So create and save a page setup which defines your plot parameters including monochrome.ctb then this page setup name will show up on the drop down list in the Publish window.
Paul Li
IT Specialist
@The Office
Message 8 of 9
WBROWNMG7FU
Thanks. This worked!
Message 9 of 9
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
