Non-standard Drawing Units Angle Settings Break Angle Measurement
jeff.lentz
Message 1 of 9
jeff.lentz
When I set Drawing Units, Direction Control to "North" so 0 degrees will be at the top, subsequent measurements of 90 degree angles report the results as "0 degrees" in both the hovering menu and in the command line. Only the floating measurement within the angle itself correctly reports the angle as 90 degrees.
Replies (8)
Message 2 of 9
What version of AutoCAD & on which Windows OS are you running this?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Message 3 of 9
jeff.lentz
AutoCAD 2018.1.2 Update, Version O.161.0.0
Windows 10
Message 4 of 9
Alfred.NESWADBA
Can you please show a screenshot of that? I have no idea what "subsequent measurements" are and when an angle is shown in the command-line.
For me a measurement of an angle means the angle between 2 objects, and therefor the setting of 0° to north does not influence that. The only situation changing the 0° direction I see is to construct objects, so to enter relative coordinates from a startpoint with a direction and length (for a line), then the direction can be use with 0° to get a line in direction to north. But for measurements ...?
That is what I see while creating a line with 0° set to north, working well for me, if that is your issue:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 5 of 9
jeff.lentz
Maybe this screen shot will help. I measure between two simple lines on the screen and get 0 degrees reported on the command line and in the hover menu, but 90 degrees reported on the drawing itself. My settings are also shown in this clipping. If I switch Units, Direction back to the default East, it reports 270 where it reported 0 previously. That also makes no sense, so maybe I don't understand what the tool is reporting.
Message 6 of 9
Alfred.NESWADBA
Thank you for the screenshots! I can reproduce the issue, with 2019 as well as with 2020.
When having dynamic input on you get at least a dimension like object that shows the correct angle. Having dynamic input off means you only see one result in the command-line and that shows 0° ... which is not correct.
At least ... 2014 tested, same issue.
- alfred -
Alfred NESWADBA
Message 7 of 9
I've actually never used the MEASUREGEOM command to measure angles.  I usually use the Dim Angle option.
Perhaps it's an AutoCAD bug when UNITS Direction Base Angle is set to North.
Message 8 of 9
cadffm
west=270
south=180
LOL
Start a supportcase as bugreport
I am sure you are not the first, but after so many years (tested in 2013), Adesk should wake up.
Sebastian
Message 9 of 9
jeff.lentz
I couldn't imagine using DIMANG to measure anything. It doesn't even work if you have a line overlaying a block feature, and once you get your answer, it's likely to be so small you can't read it or in numbers twice your screen height. I have MEASUREGEOM on my customized ribbon tab so I can do measurements and such without typing it or hunting. I give it a workout.
