AutoCAD Forum
No way to cancel Find and replace function
14 REPLIES 14
Message 1 of 15
r.saravanan57RT9
795 Views, 14 Replies
I Just called Find and Replace command in a table like this. It's took 1.5 hours to finish.
There is no option in the Find and Replace Tool to cancel the function if required.
I don't know what complication exist in this function and why this much time eating by AutoCAD?
One more issue:
I could not able to work simultaneously with other software while using AutoCAD publishing process since the focus always kept in AutoCAD itself and so minimizing other software windows automatically. I am always waiting up to finish this process in order to start work in other software or Windows explorer.
We are using AutoCAD 2018.
14 REPLIES 14
Message 2 of 15
Have you tried to press esc keyboard button OR press the X at upper right of Find and Replace dialog?
Imad Habash
Message 3 of 15
Yes I tried. No response.
Message 4 of 15
Questions:
1.Have you installed all 2018 updates? Post screen capture of About command
2.Does the problem not occur in a particular dwg?
3.Have you tried command in a dwg with one text object to see how long that takes?
4.What is your Windows OS?
Paul Li
IT Specialist
@The Office
Message 5 of 15
@r.saravanan57RT9 wrote:
I Just called Find and Replace command in a table like this. ....
Like what [if you meant the table is like something, rather than just the entries in the FIND dialog box]?.  Can you post a drawing file in which this happens?
Kent Cooper, AIA
Message 6 of 15
This issue occurring only in drawing having AutoCAD Table.
In my case, i have an Table with 259 rows and 4 columns.
For one drawing/one text, no need of Find and Replace function. DDEDIT is enough. Though I don't know to how to calculate the time taken for one.
OS we are using : Windows 11 Business
About AutoCAD
Message 7 of 15
You may want to install 2018 updates. You currently have the first release without any of the many updates applied which may resolve your issue. Check out this chart that shows the first and last 2018 build number:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-tie-the-Pro...
Paul Li
IT Specialist
@The Office
Message 8 of 15
"Like this means...."  means, as shown in the picture.
I am facing this issue only in drawing having Table.
Sorry  Kent, I can't share the drawing for testing purpose since it's a Governmental Project document.
Message 9 of 15
Hi Paul,
We are always connected with Autodesk Access (Available in the notification area) and https://manage.autodesk.com/products/updates.
Up to now, we are not getting any notification about AutoCAD 2018 update. Anyway, let me check and update if applicable.
Message 10 of 15
Looks like something has fallen through the cracks. The last 2018 update was announced many moons ago
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Update-2018-1-2-av...
Paul Li
IT Specialist
@The Office
Message 11 of 15
Hi Paul,
We are using 100% Genuine AutoCAD product only.
I am explaining my issue here, if you don't have a solution, please leave it. Don't use low words.
Message 12 of 15
I’m not speaking any low words. “Fallen through the cracks” means just that. I’m not referring to illegal software. I’m referring to the fact that some mechanism has failed in notifying your organization of the updates not once but multiple times for AutoCAD 2018. It’s worth investigating.
Paul Li
IT Specialist
@The Office
Message 13 of 15
@r.saravanan57RT9 ,
Consider the suggestion from this link (specially the Audit).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 14 of 15
pendean
in reply to: r.saravanan57RT9
@r.saravanan57RT9 Modern tools like Autodesk ACCESS are not going to find 2018 updates for you since that year version is no longer actively supported. 2018 updates are not found easily at the Autodesk website. Sorry. Try here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Update-2018-1-2-av...
May I ask, why are you /your company/government paying for a subscription up to the 2024 version but you still use 2018 version? Curious.
Message 15 of 15
r.saravanan57RT9
in reply to: pendean
Thanks for the information.
Let me check.
We are using certain EXE which are developed in 2018 versions. We don't have support to convert those program's into latest version.
AutoCAD Inside the Factory
