No edit when double click
Hi! So since I've been using autocad at my job, I realise that I can not doublle click on text with leader (multileader I think) to edit the text. I need to go in the propreties and click on the button manualy. see the picture
also, when I click on a dimentions, I dont have the text editor ! So I can not put in bolt my text.....
Any solution?
Im the only one drafter at my job who have this problem..
Thanks!
Math autocad 2018
dbroad
Might you have turned off DBLCLKEDIT?
Architect, Registered NC, VA, SC, & GA.
It is working for normal multiline text ( the text editor appear as well)
CAN YOU SHARE THAT FILE
The problem is not the files.. I tried it on different computer at my shop and on it is only in my computer that I have this problem..
It dose thta in ALL the files
dbroad
You might try resetting your AutoCAD profile on that computer and see if the problems still persist. Other solutions that are more involved are doing a repair install and a reinstall.  Of course, those solutions will probably hide the source of the problem.
Thanks, I just did that and it is working!
