- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Normally, a drawing won't require saving unless something has been modified.
My problem is that when the drawing contains a constrained dynamic block it does.
The DBMOD system variable (drawing modification status) should be 0, but for some reason it's not.
An asterix appears in the drawing tab, which is another indication.
Is this just a bug in AutoCAD that I have to accept?
A simple constrained block in a drawing attached.
I'm running ACAD 2018. Could someone let me know if it has been fixed in a newer version?
