Importing excel data into attributes AutoCAD 2021
kwrightKDC7A
kwrightKDC7A
Hello!
I am trying to create a link between an excel file and CAD file. I would like text data from excel to fill in predefined attributes once the excel data is imported.
I was working off of this SOP:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Here is what I have done:
  • Created text attributes where I need them and but them into one block. (ex. Project name, Project location...)
  • Exported attributes to a TXT file
  • Copied this data into an excel file
  • Linked the project specific data to the cells for the attribute Value
  • Go to import the attributes but it seems it will only allow .TXT files
I am trying to avoid converting the excel file back to a .TXT file, I want this to be something that can be done with as few clicks as possible so I can use it on all projects moving forward. The excel file will already be created for other needs so I am trying to streamline my work.
Thank you!
Kelsey
TheCADnoob
Change your excel file to a CSV file.
CADnoob
kwrightKDC7A
@TheCADnoob thank you for the quick reply.
I did as you recommended but when I click import attributes and navigate to the file folder with the CSV file CAD is still looking for just .TXT files. If I drop down on the "files of type" it only lists .TXT
leeminardi
You might find post #9 here helpful.
lee.minardi
TheCADnoob
sorry i forgot a few steps.
When you have it saved as a csv you have to change the file extension to .txt. A csv file is in essence a text file.
One you change the file extension open the text file and do a find and replace for commas (ctrl +H).
(note if you have commas in you data you will have to work your way around those)
(note to do a replace for a tab got to the last spot in your text file and hit tab. Then select it and cut it)
Hit replace all
After replacing all you data will be ready to be read in
Remember to save after you made the change.
CADnoob
kwrightKDC7A
Thank you so much for the detailed response!
TheCADnoob
Glad to help. Sorry i didn't give that response the first time. sometimes i have to step back and remember that things aren't always as obvious haha. Its a pretty convoluted process to get from changing from CSV to importing data lol
CADnoob
