AutoCAD Forum
New Drawing Opens to a Copy of Frequently Opened File
2 REPLIES 2
travis_kowalchukR9P3E
86 Views, 2 Replies
Every time I open a 'New Drawing' with the "+" sign next to the Start or other open drawing 'tab', I get a copy of a particular drawing I work a lot in containing source blocks for my palettes, rather than a blank default AutoCAD template drawing like it used to.
Is there a way I can get this fixed? I'm afraid of my original drawing being affected, and also generally open a blank drawing to test features or blocks, so having it be already modified is a royal pain....
Thank you!
2 REPLIES 2
you started a new file by another file as template!
Run NEW command, set filetype to .dwt and select your common .dwt (for example acad.dwt for imperial units).
Sebastian
Sweet thank you! This fixed my issue.
Technology Administrators
AutoCAD Beta
