I design irrigation in and around landscape beds for large gated communities. Often, when we recieve the plans for the landscape beds, instead of getting a plan showing the edges of each landscape bed, we get a plan showing the segments of each bed where different plants are grouped.
I've been tasked with simplifying these beds, to show a continuous plant bed edge, regardless of planting segments.
I'm attempting to use Boundry and have had some luck.
im using exoffset to overlap the segments before using boundry, but the issue im running in to is exoffset doesnt work on closed polylines that overlap themselves, and boundry doesnt work consistently on large selections.
am I over complicating this? there must be a way to manipulate tolerances for the Boundry command. In this example, each planting segment is seperated 6" off of the adjacent segment. but it isnt quite uniform. if i could just set a 1' tolerance I could wrap all thes pretty easily into each landscape bed through the whole community all at once....
Any help would be appreciated tremendously...
