Nesting
Nesting
Nesting
Any recomendations for a nesting solution in AutoCad? We have a circuilar piece of material and need to cut simple squares / rectangles but also some more cut complex shapes and need a quick visual that can orientate the shapes in the most economic way. Any help would be much appreciated.
timothy_crouse
This is a bit outside of Autocad Swimlane.
You will have better luck using a tools outside autocad and mimicking the results.
What you are asking requires a lot of recursive analysis.    Something like the tool below may get you on your way:
http://workshop-buddy.com/
-Tim C.
DarrenP
Autodesk has a nesting tool but it only works with Inventor: https://www.autodesk.com/products/inventor-nesting/overview?plc=PDCOLL&term=1-YEAR&support=ADVANCED&...
DarrenP
ennujozlagam
you can try to use Revit architecture and can show in 3D view. thanks
timothy_crouse
Sorry but I do not understand the responses here.
I thought you wanted a way to calculate how many shapes could be cut out of a piece of material.
Are you asking for something else?
-Tim C.
