Need Viewport to show models from arch and decimal for large area and view keeps needing regen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
as I'm working to place dimensions in a 1/16" scale viewport on an ansi d sheet showing a lot of stuff but as I work the view keeps needing to regenall to display, osnaps stop working in various areas within the same viewport (no reason they should not be available as they work if I drop into model space). I think maybe I'm asking too much of the software or hardware but then I remember its 2023 and its a plan view. If I took the time to redraw it all in 2D autocad would zoom around like it was 1985 and I just pushed the turbo boost button! But all the stuff is going to change again and I want to ref the models so as they change I'll see it and can fix without having to redraw the changes because I can't reference these huge models!
TLDR-How can I make it easier on autocad so I don't have to issue a regenall and it can just display the viewport objects like it should!
