Using an Ordinate dimension style to locate objects and sometimes the text placement would be better in the horizontal than aligned with the vertical line. Too bad you can't have it unless you waste your office Cadmin time coding something with fields to display something that should be the most basic stuff CAD can do. Just needed one dimension to be rotated and wasted over an hour when I could have just exploded or burst or even called out "go look at this table of dimensions I couldn't get to display properly" then typed out the dimension manually like the first CAD users who used this program like a digital pencil. That's old skool and not cool!
