AutoCAD Forum
Need support for ".NC" for CNC file exporting format
5 REPLIES 5
1853 Views, 5 Replies
I need support for .NC exporting, can you add this format?  I need it both for AutoCAD and Inventor and .step for AutoCAD also.
5 REPLIES 5
john.vellek
Hi @Anonymous,
Here is an article that lists the current export options from AutoCAD.
[EDIT] It appears that your Mastercam software can import DWG and DXF files directly from AutoCAD.
Thank you for posting about this issue in the forums.
You are also welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email autocad.beta@autodesk.com or autocad.lt.council@autodesk.com
John Vellek
pendean
Which CNC software or device are you using exactly?
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
in reply to: pendean
I am using AutoCAD to design but need .NC file to make part with the CNC Machine.  It use Master CAM.
pendean
What version of MasterCAM? Modern versions have a wide import ability
http://www.mastercam.com/en-us/Support/Technical-Support/Translators
and
https://www.youtube.com/watch?v=5Yvtlt4adF8
AutoCAD Inside the Factory
