Need some serious help pls :(((
cota_angel51
Observer Observer
Message 1 of 8
cota_angel51
Observer
Observer
Need some help with a plotting issue. I need to plot my drawing on a letter size sheet, it's a transverse section of a house, so the drawing should fit well. I drew on meters but I need to print on a but the sheet size is on inches and whenever I go and do the scale thing with "Z" and then "1/XXxp" my drawing almost disapears because of how tiny it becomes. The red circle is the thing I need to plot, and there's also the pagesetup settings. Thx in advance guys
Replies (7)
Message 2 of 8
imadHabash
Hi and Welcome to AutoCAD Forum,
Would you please share here your CAD dwg sample for testing?
Imad Habash
Message 3 of 8
cota_angel51
Observer
Observer
Sure! didn't think i could share a dwg file, I need to plot this right here, idk what scale should I use, I know theres 1:75, 1:100, and stuff
Message 4 of 8
imadHabash
Thanks for your CAD dwg sample...
  • Check PROP 1 layout ... i modify pagesetup for mm unit paper size to meet you model units.
  • now you can get the right Scale  1:1 by Z(s)= 1xp .
Please get back if you need any more help.
check the CAD dwg file 👇
Imad Habash
Message 5 of 8
cota_angel51
Observer
Observer
TYSM, what was the problem?
And, so if I want to scale on 1:75 what command should I use?
Message 6 of 8
imadHabash
  • The problem was in VP size ( X = 0.27302,  Y = 0.20952 ).
  • You can set the scale from the status bar scale option as shown in below image OR you can select the VP itself without command and press the blue arrow.
  • Also, you can select the VP itself then Ctrl+1 to be able to change the scale(Misc section)
  • The idea is that you must have units matching with all of your CAD components( Model,Layout, VP Scale ...etc)
Imad Habash
Message 7 of 8
cota_angel51
Observer
Observer
So, the fact that the paper is on mm won't affect when printing?
Still can't manage to make the drawing fit on the sheet, its still a bit small (Im useless ig).
Message 8 of 8
imadHabash
Viewports treat like a window for your model part that you want to print ... If you want to fit it in the paper try with 1:50 (2xp)
Imad Habash
