need script file to make road cross section
arbin.singh143
arbin.singh143
hi,
      I have road width and slope height data and i want to make  the cross section by  using script in notepad
Pointdump
Hi @arbin.singh143,
Please post your data. An Excel Spreadsheet? What do you want the results to look like?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
arbin.singh143
when i run the script command the result should look like screenshot i have previously shared.
Kent1Cooper
You haven't answered the question about the format of the data on which to base such a Script.  Also, even if it's always 8 units horizontal and 0.6 units sloped, the length dimension on the angled part at the right end is not sufficient information -- an angle would also be needed.  [But if it's always the same, and specific numbers such as those would be built into a Script, you may as well just draw it once, save it as a drawing file, and INSERT it when needed.]
Kent Cooper, AIA
