I'm using AutoCAD 2023, and I'm facing a problem with one of the options of the UNDO command, the option I'm mentioning is the AUTO option.
AUTO is an option that is on by default and causes AutoCAD to undo the action of the whole command rather than the individual actions within a command.
The problem is, I did turn it off and AutoCAD is still undoing the whole command! It was supposed to undo the steps of the command reversely by order, not the whole command.
For example, when I draw a series of lines using the LINE command and try to undo it (Auto Option Is Off), AutoCAD undoes the whole process at once again just like the case I was setting the AUTO option on.
I attached a small video that shows me trying both modes (ON/OFF) and getting the same result, hope it helps you understand my issue.
Ahmed Tareq
