Good Morning,
I have an issue with eh NAVCUBE and the UCS orientation. UCS is in WCS and plan but the ICON is upside down and in the NAVCUBE, the compass is correct but the cube is rotated 180 degrees. I do not find anysettings ou of order.
Solved by ed57gmc. Go to Solution.
Rotate the view so that in WCS, the X axis arrow is pointing to the right and the Y axis arrow is pointing up. This will be the correct Plan view. Then hover over the view cube, right click and select "Set Current View as Home".
