AutoCAD Forum
Name of the edited Block
9 REPLIES 9
Message 1 of 10
pascal.fournierRVU8D
735 Views, 9 Replies
Hello, I would like to have visual information on the name of the block being edited when I am in the block editor, this existed on old versions. Sometimes I need this information when I make a lot of changes to a block. I generally run the "Test block" command to have access to the properties but it is not the most practical! THANKS.
Tags (1)
9 REPLIES 9
Message 2 of 10
pendean
Community Legend
Community Legend
'test block' command? Do you mean while inside BEDIT command, BTESTBLOCK command?
Which year version back was it performing differently? I don't remember anything different.
Message 3 of 10
paullimapa
Just open the Properties window and the name of the Block currently being edited is shown under the Block section next to Block name column
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 4 of 10
Kent1Cooper
[Which variety of Block editing are you using?  I find that @paullimapa's suggestion in Message 3 works if it's BEDIT, but not if it's REFEDIT.]
Kent Cooper, AIA
Kent Cooper, AIA
Message 5 of 10
cadffm
in reply to: Kent1Cooper
cadffm
Block Editor is BEDIT, and for RefEdit: REFEDITNAME
( @pascal.fournierRVU8D  I also can't remember that there was a change in BEDIT)
Sebastian
Sebastian
Message 6 of 10
Thank you very much for your response @paullimapa , I would add a little clarification, no element of the block must be selected to have this information. In version 2006 of AutoCAD, the name of the block being edited was displayed above the graphics area.
Message 7 of 10
Thanks for your answer, I'm French, our commands are translated 😉
Sorry for the confusion.
Message 8 of 10
cadffm
This is the old style / Bedit Toolbar.
Since 2009 the ribbon is standard and if you are using the ribbon, there is no field like this.
follow the steps:
Command: RIBBONCLOSE
go to Command: BEDIT
you seeing the toolbar you talked about, incl the name field
Command: RIBBON
Sebastian
follow the steps:
Command: RIBBON
Sebastian
Message 9 of 10
cadffm
in reply to: cadffm
cadffm
follow the steps:
Command: RIBBON
* If you like to have both (ribbon & whole toolbar), that should be possible by, but it wasn't the idea of Adesk / no standard.
Sebastian
follow the steps:
Command: RIBBON
Sebastian
Message 10 of 10
C'est exactement ça que je cherchais ! Merci beaucoup @cadffm 👍
C'était quand-même mieux !
AutoCAD Inside the Factory
