My product won't launch. It is stuck on initializing
Message 1 of 9
Replies (8)
Message 2 of 9
s.borello
Do a clean install.
Message 3 of 9
imadHabash
what product .....  what version .... what windows ?
When AutoCAD failed to start, there are many things that can cause this. It can be viruses, Windows problem, hardware drivers, Windows settings and  AutoCAD problem itself. It’s not easy to find what went wrong.
Imad Habash
Message 4 of 9
Tiana_Y
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @s.borello and the information that  @imadHabash  provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
Message 5 of 9
Thanks for the suggestions.  I had to do a re-install.  I suspect a recent Windows update was to blame.
Message 6 of 9
Pls transfer give it to me your answer for my Autocad 2006 product activation & registration code. you gave me only 30 days remaining for Autocad registration & activate this product. you demanded to activate the product, recognized product activation code'll be demanded after I've properly configured it for my Autocad 2006 software , you've required it. enclosing this answer write send to me. Consisting it I can launching the product entirely to make " Finished" No problem.
Message 7 of 9
bturn
Community Visitor
Community Visitor
I just had the same issue and ran as an administrator and it opened just fine. Try this before doing a clean install and it could save you some time.
Message 8 of 9
180021860
Community Visitor
Community Visitor
I'm having that problem on AutoCAD web.
Message 9 of 9
pendean
Community Legend
Community Legend
@180021860 AutoCADWEB is a browser based software: the correct forum for your support is over here
https://forums.autodesk.com/t5/autocad-on-the-web/ct-p/5072
Tip: change browsers and see if that helps. If you are in a ChromeOS device, you might just be out of luck though.
