DXF FILES UNABLE TO OPEN IN AUTOCAD
arq.vr02.fernheim
Message 1 of 22
arq.vr02.fernheim
Hi Guys
thank you for al the replys. Since a got the new autocad, some problems don´t exist anymore.
but i got a new one.
Autocad abort when i want open a dxf file, made from Qgis, in autocad versions before, there where no problems at all. And it shows me this:
fatal error e0434352h exception at f71e9129h
If i drag in drop the document at a drawing, it perfectly makes a block wich i can use. I just wanna know why i cant open the document normaly
Replies (21)
Message 2 of 22
cadffm
Wow, that's cool, real new informations for me related to this exception error  (cool, if you can share one dxf file with us/me)
Would you please upload one file?
What is your product-version (best answer is: Screenshot of ABOUT dialog)
Sebastian
Message 3 of 22
natasha.l
Hello @arq.vr02.fernheim
This is a system related error, please try to use your Event Viewer. Try to re-create the event/pull up the error again & locate the event error, then search for it online this will help you determine the root cause.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 4 of 22
arq.vr02.fernheim
yes, here is one
Message 5 of 22
cadffm
@arq.vr02.fernheim
We are missing your attachments..
Login via Browser and attach the file(s) as *.ZIP
https://forums.autodesk.com/t5/autocad-forum/dxf-files-unable-to-open-in-autocad/m-p/8957505#M989131
Sebastian
Message 6 of 22
arq.vr02.fernheim
sorry, can i mail it to you, my ubload is not working. Internet in this corner is sometimes working
Message 7 of 22
cadffm
It is a DXF2004, so that it is not easy to describe the problems exactly (Auswand / time),
but you should be able to open the file using the RECOVER command,
Execute ZOOM EXTENT, save as.
sorry, Weekend..
Sebastian
Message 8 of 22
arq.vr02.fernheim
Thanks for the reply, but that i tried to, won´t work. If it is a 2004, well i have autocad 2020.
have a nice weekend.
Message 9 of 22
cadffm
SORRY, my fail.
2020 crashed by OPEN AND BY RECOVER, sh*t.
2013 for example is able to recover the damaged file (there are multiple problems in these files, it's a Qgis export bug).
Sebastian
Message 10 of 22
arq.vr02.fernheim
Ok then, i reinstal the QGIS, and if you know the bug - let´s send qguis a report
The file you send me, works fine!
Message 11 of 22
arq.vr02.fernheim
Well i found some information
https://forums.autodesk.com/t5/civil-3d-forum/opening-dxf-created-in-qgis/m-p/8622315#M393364
These guys have a similar problem with dxf files, and also qguis relatet.
You where right it is a QGIS problem. If i make SAVE AS the Layer in QGIS, the Autcad will crash. If I export the layer it will work fine. But it will export the geometry as individual blocks. Thats sometimes ok, and sometimes not so ok.
Autocad 2013 works with the dxf files just fine, I could not find any version change in QGIS for the dxf file - it still 2004 even if I have the latest version of QGIS.
Thanks for your help. It shed some light on the Problem
Message 12 of 22
Alfred.NESWADBA
may I ask as you are working with QGIS ... do you work with AutoCAD or AutoCAD Map 3D?
The reason for that question is that AutoCAD Map 3D has GIS-functions, can connect to GIS formats like SHP, SQLite, MS-SQL Server, Oracle Spatial, ... so you might have a better workflow if you connect to these datasources using the Map3D FDO functionality than to use a (dead) data-exchange of DXF (dead because the DXF will not be updated when the GIS dataset has some modifications).
AutoCAD Map 3D is part of AutoCAD+Toolset, so maybe a good thing to use for that type of data.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 13 of 22
cadffm
>"Autocad 2013 works with the dxf files just fine"
NO, there are some error in QGis files, but 2013 are less sensitive as 2020.
Without recovering the file Acad2013 will also crash by Ctrl+A or some other functions (with other error messages).
I think to know what it.
Sebastian
Message 14 of 22
arq.vr02.fernheim
Sorry, mine (2013 edition) just ask for read only. Thats all. It dosent crash.
Yes, if I fix the drawing it fixes a error, but 1 only.
Message 15 of 22
arq.vr02.fernheim
That is correct, the 3DMAP from Autocad can open the shape file and work as a data exchanger.
But it also has trouble with the DXF file made by QGIS
Message 16 of 22
cadffm
Lucky QGis - User
Update your product and you will be able to recover the file.
https://manage.autodesk.com/home/
Today 2020.1 is the right version/Update.
Open file by RECOVER,
saveas dwg format,
close and
reopen the file- by recover if you like or just open
AUDIT,
-PURGE reg * no
-PURGE all * no
QSAVE
Now on missing Plotstyle data is created (since fileformat2004 needed)
ACAD_LAYOUT Data for Model and 2 Layouts
and ...<break>, I found enough and the (for me) important informations, thats enough.
Acad missing some data what required for 2004 and more also for 2000 (and later).
Ist QGis nicht auch deutsch? Dann könnte ich durchaus noch versuchen 2,3 Hinweise zu geben,
aber da es in den letzten 20Jahren nicht geändert wurde...
HTH
Sebastian
Message 17 of 22
arq.vr02.fernheim
Thanks for the info, i gona try it, as soon es posible, because reeinstall or ubdate takes time.
Message 18 of 22
arq.vr02.fernheim
that solves the problem. Thanks a lot.
Message 19 of 22
cadffm
Your 2013 can detect and solve more problems, depending on how to do, the workflow order and file-format,
but i wonder if your 2013 will not crash by my as sample stated CTRL+A.
Would you please test it a second time? Just open the file in 2013 (or in 2020.1) and press CTRL+A for 'selecta all': No crash?
>"that solves the problem. Thanks a lot."
2020.1 is just less sensitive for some data problems than 2020, but the source problem (corrupt/missing data) still present - in the QGis dxf file.
I am glad to have helped and if the problem is sent to the manufacturer, the better.
Sebastian
Sebastian
Message 20 of 22
arq.vr02.fernheim
2013 CRTL+A  = no crash befor or after audit run.
2020.1 CRTL+A = crash befor and after audit run. - but, you can save the file as .dwg make the CRTL+A, and save back as .dxf
