Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
My plan is not extruding and command line is saying one object is removed.
Please help me guys my plan is not extruding i have join every thing the whole unit is joined but i don't know what the problem is....The file is attached.
S.Faris
Error :
Command: EXT
EXTRUDE
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to extrude or [MOde]: 1 found
Cannot sweep or extrude a self-intersecting curve.
1 object removed from selection set.
Select objects to extrude or [MOde]: *Cancel*
Solution :
Do a Boundary inside the wall and create another polyline which will help to remove Self Intersection error.
SALMANUL FARIS
neaton
You can also use PRESSPULL and select in between one of the walls. PRESSPULL extrudes any enclosed area.
Nancy
please elaborate
S.Faris
Type BO(Enter)
Pick inside the wall(as if you were to hatch the wall)
now press enter.
This will create another polyline of the walls.
Try using extrude command and select the newly created polyline and it should work.
Or if you are finding it difficult to get this done, as suggested by @neaton you can use PRESSPULL command and pick inside the wall, and type in the height value.
SALMANUL FARIS
