I have and Alclad plate with a mounting flange on each side. To improve the rigidity, I want to put a folded flange at each end (not for mounting).
Just before the sheety bends the material, the sheety must drill a 5/64 inch hole in the 90 degree corner at each end where it will be bent for relief purposes. The flange is bent to 90 degrees with an inside radius of >3x matl thickness.
Can you help me put the steps together to get it right? See attached DWG file.
Thank you.
