AutoCAD Forum
My Autocad to slow can't active (Shadeh with edge (fast))
3 REPLIES 3
Nanda.SetiyoHadi
303 Views, 3 Replies
Hello, please help me. Before i use AUTOCAD 2024 i use latest version AUTOCAD 2023. The fiture of (shaded with edge fast) work perfecly, and can edit my 3d project so smoot. In new version AUTOCAD 2024 this fiture can't active in same drawing project, but can active if i open new project
3 REPLIES 3
CGBenner
in reply to: Nanda.SetiyoHadi
@Nanda.SetiyoHadi
Welcome to the forum!
Can you share any information about the computer you are using, and what kind of graphics card you use?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Core i7-11700
RAM 32GB
VGA AMD RX640
pendean
Have you installed the 2024.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024, see if that helps.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
AutoCAD Inside the Factory
