Multiple Windows
Multiple Windows
JohnC_ISM
Message 1 of 14
Multiple Windows
JohnC_ISM
im searching and im finding the opposite issues or specifically the views of a drawing but thats not what im looking for
so far this hasnt been an issue until randomly this week i havent changed anything and yet somehow my open windows layout has changed. i want it to open multiple windows on the taskbar. not tabs or internal windows where i have to minimize inside of autocad i want to be able to switch by clicking the other window similar to the two windows shown in the attached picture.
i never changed any setting yet it somehow changed.  see the image attached what i dont want
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
@JohnC_ISM right-click on the Windows Taskbar, select Taskbar Settings and explore... https://geekflare.com/customize-windows-11-taskbar/
Message 3 of 14
JohnC_ISM
no i know how that works and in this example you can see that it already creates its own separate windows.
Message 4 of 14
paullimapa
Sounds like you don’t want to open more than a single dwg in an AutoCAD session
With only 1 dwg opened see if command SDI returns 0. If it does change it to 1.
Paul Li
IT Specialist
@The Office
Message 5 of 14
JohnC_ISM
well that seemed to work. ive never even seen that option so im not sure how it changed at all.
Message 6 of 14
paullimapa
Perhaps you might have ran a plugin that turned that option off and didn’t turn it back on?  But glad to have helped….cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 14
JohnC_ISM
now it went back to what it was doing and SDI is set to 0 already. it looks like it switched to tab mode up at the top. i know FILETABCLOSE but then it puts me right back where i started with two windows and one autocad thing in the windows taskbar
Message 8 of 14
JohnC_ISM
heres what i mean.
- i dont want tabs
- i dont want drawing 1 to open just the drawing i click
- and if i open two i want two autocad things at the bottom
whatever helps. thanks
Message 9 of 14
paullimapa
No you forgot. SDI needs to be set to 1 for what you want so AutoCAD only opens 1 dwg and no more.  Something must be turning this setting back to 0 which you don't want. Time to investigate what might be doing this.
Paul Li
IT Specialist
@The Office
Message 10 of 14
JohnC_ISM
Okay that fixed that I accidently forgot I had a thing in the lisp to set it to 0 from last time I was messing with it.
Now how do I get it to stop opening up drawing 1 and the drawing I click on? startup is set to 0.
Message 11 of 14
paullimapa
Message 12 of 14
JohnC_ISM
Ive tried all start ups and they all open drawing one separately. I have no idea how or why this happens.
Message 13 of 14
paullimapa
that's odd...both in 2023 & 2024 once I set SDI to 1 and STARTUP to 2 and I launch AutoCAD from the shorcut the program opens without loading a drawing like this:
Paul Li
IT Specialist
@The Office
Message 14 of 14
JohnC_ISM
Its something with my setup. Idk whats going on because now after loading a big GIS shape file all my menu bars and palletes reset. I'm guessin this is just my computer because this is so annoying haha
