Multiple sheets plotted to a single PDF
I am trying to plot multiple sheets to a single PDF file....I used 'Help' and read about Batch Plots, etc., and I can get them to plot to a single PDF, but the final result shows the drawings in Model Space rather than Paper Space...I have read more but cannot figure out how to do it....I manage the plots and select the window of the Paper Space drawing with the Title Block, etc., but when the plot comes out it shows the full Model Space view...thanks...John Sheffield
pendean
Community Legend
Community Legend
PUBLISH command will list all tabs, model and paperspace: it is up to you to delete the modelspace layout you do not want.
Or get in the habit of setting PUBLISH command to always ignore modelspace tabs, by right-clicking in the Sheet Name area and unchecking this
It only seems to be listing the model views, but I removed them and added some paper views from the files, and also set the default not to see model views and successfully plotted a multi-drawing pdf...will work more on it tomorrow before releasing in case I have another question and thanks so much for your help...js
jayhar
Find the attachment, plot multiple sheets to a single PDF file
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
thanks
