I have three lines in multi line attribute, now I am inserting field so I can manage text using Sheet set manager. Now for specific need I want multi line text in custom way, for example as per image in first line I need "PIPING & INSTRUMENTATION" in second line I need only "DIAGRAM" in third line I need "GAS TURBINE GENERATOR". Now problem is I am not able to move "GAS TURBINE GENERATOR" in third line. So much appreciated if anyone can help.
I have tried several ways and all failed except one.
Can you move DIAGRAM to the 3rd line?
or... make (3) Fields that you have to edit for each of your drawings thru Properties.
This would be harder to edit vs Rename & Renumber but would work.
This way would also be harder if your auto making a drawing index with sheet sets but it can be done with spaces.
Hope this helps.
JRR!
Thanks for tried and suggestions, Actually I need Diagram after P&ID so I cant move it last.
Other solution you provide is good and I also think about it but I need to make index from all drawing sheet and if I will separate all three line for three field I cant called out to prepare Index. So I am stuck at this point.
Once again thanks you and pls let me know if you come up with better idea.
I've done it in the past with 3 fields and in my index, I concatenated the 3 fields so that it fit on one line. It depends on how you are creating your index.
Thanks for having some trick to manage Index, Can you pls elaborate how to concatenated 3 fields in one line.
What tool are you using to print an index?
To make Index I am using Insert sheet list table tool as added image.
Not sure how I can combine three field into one line as you mentioned.
Here's a video of how to do it.
