AutoCAD Forum
Multileader block, edit attribute box
3 REPLIES 3
Thomasbatson
2361 Views, 3 Replies
I am using autocad electrical 2018 and use that for everything, but I need to use the multi-leader.  I created a custom style that uses the circle source block to have the number in the middle.  The instructional I saw had the Edit Attributes box come up immediately after inserting and pressing enter, but I have to double click to change the text to my number.  Does anyone know how to get it to pop-up automatically?  I posted a picture as well.
Thank you.
3 REPLIES 3
ВeekeeCZ
in reply to: Thomasbatson
Attdia or attreq?
gotphish001
Post a dwg with the multileader style you made in it, so we can see what you did. Is the block with attributes inside of another block?
Nick DiPietro
Cad Manager/Monkey
Thomasbatson
in reply to: ВeekeeCZ
It WAS the ATTREQ, I set that to 1 and it works.  That is awesome.  Thank you very much.
I posted the drawing just in case for future reference as well.  Now when I insert the leader, it uses the circle block (standard ACAD) and then pops up the dialog box.
Forma Design Contest
