@ethan.thoenes wrote:
Very annoying that this cannot be set by default -- hopefully they fix this one day. I often have to overlay text over images and good masking functionality would really be helpful.
Unless you are stuck in an older version of LT... you can ask for guidance on how to customize AutoCAD to help create what you need all the time if creating a master Template file to pull customized (and custom named) "styles" is not working for you: which of these programming languages do you feel most comfortable using:
https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
If none, start a new post in the LISP forum, be very detailed about your needs, share a sample DWG of your desired settings, and the good folks over there will help get you started.
