Reverse history of a solid
Karol-Or
Karol-Or
I can't i reverse the union action in a solid.
I have recorded the history and selected Separate in Solidedit but it keeps asking to select a solid
john.vellek
Hi @Karol-Or,
You should be able to remove the UNION using SOLIDEDIT as described in this article.
John Vellek
beyoungjr
Since SEPARATE doesn't work too good on your model I would suggest you try holding CTRL while left-clicking the parts of the object you want to alter.  I typically copy a solid and use the CTRL-Click method to delete the part that I no longer want.  Having a copy/copies allow me to work the model edits and keep my original in case of "OOPS".
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Johanna_Esteban
Select the solid, go to properties and change Solid History Record to NONE. (see image)
In attached the new file.
It's all
Regards.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Karol-Or
Although i use 2013 i found the answer in your link. my composite solid is made of overlapping primitives.
