AutoCAD Forum
multi-line customization
3 REPLIES 3
M_H_G_M_G
433 Views, 3 Replies
Hello every one ...
i want to make a multi line that have a field and this field contain the length of the multi line
like that image
 and the field is this red text , the length of the multi line and it divided by 1000 to convert length from mm to meter
and rounding to the largest by 0.50 m .......
3 REPLIES 3
Valentin-WSP
in reply to: M_H_G_M_G
@M_H_G_M_G ,
You can achieve this by a LISP similar to the one on this >>LINK<<.
Consider asking in the Visual LISP, AutoLISP and General Customization Forum.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Kent1Cooper
That is not within the capabilities of MultiLine definitions.  But you may be able to do it with a dynamic Block.
Kent Cooper, AIA
pendean
Not an option with MLINES. Sorry.
Blocks or Dynamic blocks are your answer.
Forma Design Contest
AutoCAD Beta
