multi-leader scale
multi-leader scale
multi-leader scale
I have a multi-leader with circle. I want the text inside the circle to be the same size, but enlarge the circle. How to do that? Thanks
chriscowgill7373
you can try editing the block to be a larger size circle.  I believe the block you are looking for is called _TagCircle.  you should be able to scale up the circle, save the block and it should propagate to all of your mleaders, plus new ones.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
HI
Please follow below procedure.
1.) Goto Block editor (BE)
2.) Select Block (NAME CONTAINS TAG CIRCLE)
3.) Now Select the Attribute (NAME CONTAINS TAG NUMBER)
4.) Then change its text height in properties.
