MText not visible inside block editor
vinodkl
Mentor Mentor
vinodkl
I have this strange problem, I have the Mtext which is inside the block. But when I go into the block editor the text is not visible only the grips are visible and I am not able to edit the Mtext. Help me out !!
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ian.mag
Hey,
Kindly upload the file for testing.
vinodkl
I tried the drawing on another system its working fine. But on my system I have this problem.
ian.mag
Hey,
At least provide a snapshot so that we could understand your issue. Thanks
BrianBenton
If you could upload the file so we can look at it that will help us help you. That will make troubleshooting the issue much easier.
Make sure all of your layers are on/thawed. Make sure the font being used is loaded. Make sure there isn't some item in the block that is causing a "zoom extents" issue so that you are zoomed way out in the block editor and can't see the text item.
Can you see the text object outside of the block editor?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
jayhar
1, Did you set VISIBILITY in block editor??? find the attachments
2, If the text is in Layer 0 and Layer 0 is turned on and not frozen, but the text does not appear outside of the block editor, Check it
Please upload your cad file
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
john.vellek
Hi @vinodkl,
I haven't seen a post from you in a bit on the status of this problem.  Is it possible to attach a sample file that exhibits this behavior? You can erase and purge any sensitive information.
Please eTranmsit the file and make sure that the settings will include the fonts that are in the drawing file.
John Vellek
