Insert Georefrenced Image into Autocad (not map)
neam
neam
Hi everyone
I tried using the GeoRefInsert and Georefimg Plug-ins (downloaded from App Manager) to insert downloaded photos from Google Earth by SASPlanet software (or another software whit create georeferencing file) in correct position (UTM) into AutoCAD
(like mapiinsert in map or civil 3d and like rasert insert in Raster Design).
Is it possible to do this in AutoCAD ?
pendean
Community Legend
Community Legend
You need the other software you've identified.
ChicagoLooper
SASPlanet doesn't give you a world file that's consistent with your drawing. If I'm not mistaken, SAS world files are only available for (A)EPSG 3395, World-Mercator, meters, (B)EPSG 4326, WGS84, Latlongs-degrees, and (C) EPSG 3785 which is deprecated (no longer supported). In order for SAS imagery to position correctly in UTM using Plain Vanilla AutoCAD, you need UTM-19north projection, which SAS does not provide.
Unfortunately, the dwg you uploaded, is not using a UTM projection. The projection in your dwg is IRAN-39 and your image world file is Lat/Long 84. Neither your dwg nor your world file is using UTM.
If you have Civil 3D or Map 3D then you can do it because these programs have the ability to transform the world file to the dwg's 'assigned coordinate system.' If you have Civil 3D or Map 3D, try doing this:
  1. Change your work space to Planning & Analysis.
  2. Enter MAPCSASSIGN on command line.
  3. In search box, enter IRAN.
  4. Select IRAN-39, then click ASSIGN.
  5. Go to Insert tab>Image Panel>Image Icon. Navigate to your downloaded image. Select the image, click OPEN.
  6. Keep all default values. Click OK.
Using Map 3D and 'Assigned CS' = IRAN-39.Using Map 3D and 'Assigned CS' = IRAN-39.
Chicagolooper
neam
thank you ChicagoLooper
If you let me call you Lord of the UTM from now on
